94 turbo swap in 92 wagon wiring problems HELP!
WagALeg92
Post by WagALeg92 »
So I did a swap last weekend on my 5 speed 92 L Wagon from a 94 turbo automatic sedan I swapped the motor, cross-member, wiring harness and dash. after the swap I found that my indicator light saying my hatch was open was on all the time and the interior lights did not go on when my door opened, also the seatbelt light was flashing all the time but the automatic seatbelts still work. So I replaced the dashboard harness from the 92 5 speed after looking at wiring schematics, I found that due to the park neutral drive lights the pin connectors were different for the instrument cluster. now I have corrected all the problems except for the seatbelt light however I have found a new one If I turn on the blower motor for the heater my Illumination fuse blows. any help on this problem would be greatly appreciated in the mean time ill look through the wiring schematics for both cars.
Thanks -Frank-
1992 Subaru Legacy AWD Wagon
Daily Driver
Re: 94 turbo swap in 92 wagon wiring problems HELP!
Frank,
So all you did was swap in a 5MT to replace the 4EAT? If so, I don't see how that could have caused any of your problems unless some of the wiring may have been pulled on or messed up.
Can you provide some additional details on everything you did with the swap? Did you follow my write-up? Is the TCU still installed?
