WTB version 2 STi Intake Mianifold
Looking for a version 2 with or with out injectors. must have throttle body too
Re: WTB version 2 STi Intake Mianifold
No interest in my 20k intake manifold, huh?
Is there a difference in flow or anything? Or are they alike other than being red of course?
A version 2 manifold will be the same as an EJ20g intake. The color being the only difference.
mx4life wrote:Is there a difference in flow or anything? Or are they alike other than being red of course?
Here's my thread. I don't know if it necessarily flows better, but the motor that it came on was rated at 280hp from the factory.
http://bbs.legacycentral.org/viewtopic.php?f=15&t=46422
And if you don't like Mike's, I got a v3 sti 20k w/ tb also have injectors and fuel rail.
1994 Legacy Sport Sedan.
1991 Legacy Sport Sedan.
how compatible is it with my version 1. what mods do i need to do if none at all (coolant hoses and such)
Well it has an straight under turbo inlet, so no more silicone 90* hose off your turbo. You'd run your wiring harness on it, and may/may not need to extend any wires. Your coolant pipe will fit under it, or you can use the ej20k one I'm including. Coolant hoses are routed the same way I believe. Coolant tank bolts to the same spot.mx4life wrote:how compatible is it with my version 1. what mods do i need to do if none at all (coolant hoses and such)
