Different tires?
Smoothinto2nd
Different tires?
Post by Smoothinto2nd »
I JUST bought a used but almost new set of snow tires on wheels for my 92 touring wagon. A few days after putting them on I got a flat by hitting a pot hole and I now have a hole in the side wall on one of the tires.
I tried to find a replacement tire of the same size and model but they don't make it anymore.
Do I have to get a whole set of 4 tires again? I've read that while you are supposed to it's only really an big issue with the cars with a LSD.
I was thinking I could try to replace the front two tires with a pair from the same company that way there'd be less variance of tire size between company to company but I just don't know.
Any help would be awesome.
Re: Different tires?
You're supposed to match all four, at least within 1-2 32nd's tread depth, according to the manual. Have you checked on ebay? I was able to find nearly new tires (that were also discontinued) with the same tread as my other two. Took a few weeks of searching, though.
The overall tire circumference is supposed to be within 1/2" I believe between all tires. So if you can't find the same tire, you may be able to find a tire with similar circumference. Remember that a tires circumference may change between unloaded and loaded (i.e. no weight on the tire vs. weight on the tire)
