Banjo Bolt
94TurboWagon
Banjo Bolt
Post by 94TurboWagon »
Wondering if I can find a longer oem type Banjo Bolt to use with aftermarket stainless lines, which have the thicker opening and barely enough threads screw into the caliper. Havent bled the brakes yet and driven it so Im not sure if they will leak. The stock Banjo bolt is a 10mm X 1 If anyone know if there is a longer bolt that will work with this application let me know. I know once we had to drill out a longer bolt as no parts stores carry anything.
Thanks,
Dan
95 Svx 75k miles
98 Outback Limited 142k miles
06 LL BEAN 115k miles
Re: Banjo Bolt
