Banjo Bolt
Posted: Wed Mar 23, 2011 8:37 pm
by 94TurboWagon
Wondering if I can find a longer oem type Banjo Bolt to use with aftermarket stainless lines, which have the thicker opening and barely enough threads screw into the caliper. Havent bled the brakes yet and driven it so Im not sure if they will leak. The stock Banjo bolt is a 10mm X 1 If anyone know if there is a longer bolt that will work with this application let me know. I know once we had to drill out a longer bolt as no parts stores carry anything.
Thanks,
Dan
Re: Banjo Bolt
Posted: Thu Mar 31, 2011 6:31 pm
