I have a few failed/failing HLAs. When I take my valve cover off am I going to just be able to unbolt the rocker assembly from the head and take the whole thing out? Any problems going to be waiting for me when I go to bolt everything back in?
I found an End Wrench article describing it but they specifically mentioned leaving one of the bolts threaded in, but never gave a reason why. Will I be screwing anything up by lifting it all the way off?
This is on a 2.2L non turbo by the way, not sure if the turbos are any different.
Thanks in advance...
--Andy
HLA replacement... one thing I can't find
2005 Impreza 2.5RS. Traded :(
1991 Legacy L w/1994 EJ22T, 16G, WRX 5MT. Sold :(
1993 Legacy L AWD 5MT, 153k miles and many, many more to go.
2008 Legacy 2.5i Limited
Re: HLA replacement... one thing I can't find
Maybe they're talking about leaving the center bolt on, so the rocker doesnt just fall off, and then removing it. Its really easy actually. Done it a number of times. There's nothing you can screw up. Pull the whole thing out.
1994 Legacy Sport Sedan.
1991 Legacy Sport Sedan.
