wtb ej20k cams or customs ground for 25d swap
church207
Post by church207 »
as title say im looking for a set of not stock cams for my ej25d head swap and shimless buckets setup pm with what u have thanks
MikeyMeyagi
Re: wtb ej25d aftermarkt or custom ground cams
Post by MikeyMeyagi »
if your using the heads on a turbo application, EJ20G or EJ20K cams will drop right in. EJ20H and EJ20R cams also should work, but i cant confirm from experience.
*sold*
church207
Post by church207 »
do those cams make a differnce or would it be worth getting custon delta cams as i already baught a set of deltas for my 22t heads but decided to go back with the dohc heads
Florin1
Post by Florin1 »
I have oem na 25d cams. But they're neither of the 2 kinds you're looking for. Lol
1994 Legacy Sport Sedan.
1991 Legacy Sport Sedan.
dkopp
Post by dkopp »
church207 wrote:do those cams make a differnce or would it be worth getting custon delta cams as i already baught a set of deltas for my 22t heads but decided to go back with the dohc heads
which grind did you go with on the delta cams? if you are looking to sell those, let me know. i have some interest. regretting not doing that when i had the heads done and the motor apart, but i was pressed for time and needed to get the car back together. such is life.
church207
Post by church207 »
i have a set of 220/230 grinds for the 22t heads i was gunna stay with stock head and be happy with what i got but i want over 300 so i think i wanna go with the dohc heads i have done all three befor 22t heads 25dohc head and 25 sohc heads but i like the dohc it makes it an animanl up top im running a 16g my first setup was the 22t heads 16g 15psi headers full exhasut intake front mount fcd RWD maybe 238 horse no tune ran pritty good but now i got a motor bored 20 over and gunna do a dohc at 20+ and see what i can get out of her with same kinda setup in another car i have a emanage ulitmaite for it some 660 injectors but i wanna get some cams in her while im building the motor
MikeyMeyagi
yes the jdm turbo cams make a difference, and they can usually be found for under 100 bucks
*sold*
church207
Post by church207 »
welll where are they all :lol:
wrxr4ti
Post by wrxr4ti »
I have a set of delta "cheapo" grind cams for a 25D....I was going to use them on my RS but I have a EJ20K that going in now. I say cheapo because they took .030 off the base circle. you will have to have valve made .030 bigger on the stem after the keepers made.....I was really bummed I was unable to use these.
wrxr4ti@yahoo.com is the best way to get a hold of me.
church207
Re: wtb ej20k cams or customs ground for 25d swap
Post by church207 »
looking for drop in cams
