4eat Turbo?
91legacyawdturbo
4eat Turbo?
Post by 91legacyawdturbo »
Is a 4eat from a turbo the same as a non turbo??
2002 wrx sport wagon
Josh222
Re: 4eat Turbo?
Post by Josh222 »
No they are different. Looking in the factory service manual I can see the turbo tranny has more clutch packs in there.
92 Touring Wagon Mica Black(sold)
99 Outback Limited(sold)
05 Outback XT Limited
91legacyawdturbo
Re: 4eat Turbo?
Josh is that in the transmission itself or the torque converter? The car it self is having slipping issues and trying to go on the cheap side of things. Hoping it might be a torque converter, but would a torque converter be the same??
Re: 4eat Turbo?
The clutch plates and items that would likely cause the transmission to slip is internal to the transmission. Can you provide some additional details as to when it slips and such.
91legacyawdturbo
Re: 4eat Turbo?
Legacy777 wrote:The clutch plates and items that would likely cause the transmission to slip is internal to the transmission. Can you provide some additional details as to when it slips and such.
Not really the car itself is not in my possession. My friend is buying it. All I know is that the car drives but slowly, it slips when going up hills it has no shavings in the pan. Fluid looks good and is topped off. Second trans in the car milage unknown. It takes a moment for it to engage in auto but in 1/2/3 it drives fine.
Re: 4eat Turbo?
Maybe I'm not following you.....but how does it "drives but slowly, it slips when going up hills..", but then "in 1/2/3 it drives fine"? To me it would seem that the car either drives/works ok, or it doesn't.
If you have issues only in the "D" position, it's still going to require tearing the trans down to troubleshoot. Unless your friend is getting it for a steal or has a trans lined up for cheap....I'd pass on it.
91legacyawdturbo
Re: 4eat Turbo?
Well worst case well put a n/a auto in it while we source a 5spd an the parts for a swap. The car is 1k for it being a clean car. I'll find out tonight on its shape
91legacyawdturbo
Re: 4eat Turbo?
Trany is toasted going to the local yards tomorrow there's two in a yard locally.
