please advice
kalabala2005
please advice
Post by kalabala2005 »
first thing i own Subaru legacy 92 I'm from Egypt and this my car
i have rims but it is 14
i want to buy 16 rims
should i go and buy from any store
and what editing should i do to my car or it will fit without any editing
i need advice before buy.....and is 16 rims make any different in kilo meter gauge
forgive me if my question is stupid... :shock:
Apex3
Re: please advice
Post by Apex3 »
You need 5x100 wheels, FWD offset, a tire shop will be able to help you with it if you're not sure what will fit. Nothing needs to be modified. If you get the right tire size your speedometer won't read any different, here's a reference you can use:
http://www.miata.net/garage/tirecalc.html
Re: please advice
Subarus tend to have pretty high offset. You need something in the +45mm to +55mm range to keep the tire from rubbing.
BoostedSubie
Re: please advice
Post by BoostedSubie »
You should check out the second gen (95-98) legacy gt wheels, they are 16s and look really good. I love them, i would have some on my car but I can't find any right now used. They would be cheaper than aftermarket rims if used and have the right offset.
93 Black Legacy SS
93 Legacy
97 Outback- EJ25D/22e frankenmotor
97 Green Outback
97 Red Legacy GT
98 Silver Legacy GT- Pikes Peak build, built EJ22t/205, GT3076r
99 Black Legacy GT wagon
BoostedSubie
Re: please advice
215/45-16 tires would be the closest to stock on the legacy gt rims
93 Black Legacy SS
93 Legacy
97 Green Outback
97 Red Legacy GT
Apex3
Re: please advice
Post by Apex3 »
BoostedSubie wrote:215/45-16 tires would be the closest to stock on the legacy gt rims
205/50R16 is closer, but we're talking unit percent difference in speedometer readings so it doesn't really matter.
criticalm@ss
Re: please advice
Post by criticalm@ss »
aw what an adorable post, i got a kick out of this.
92 Leggy Wagon L~2003 Baja~2006 Sti
SUBYLUV871
Re: please advice
Post by SUBYLUV871 »
i like that nissan...like BoostedSubie said the gt wheels would look nice on your car. good luck with the search.
1998 legacy l wagon
1988 ford ranger prerunner (my baby
