Why the high idle?
droveinmylane
Why the high idle?
Post by droveinmylane »
So i am driving 90 wagon 2.2 N/A and when i pull up to a stop light or stop in general the car will idle at 2250. At first it would just idle there for a second then shudder down to about a grand but now it just stays up there. Have heard about resetting the ECU by unhooking the battery for the night is this recommended? What should i do to get the idle back down I hve to almost slam it into reverse without grinding the gears to much.
:x
90 Legacy Wagon N/A.... Newest adventure
1978 Brat......Brumby2
Jessekrs123
Re: Why the high idle?
Post by Jessekrs123 »
Is the car still cold when this happens?
2015 Subaru BRZ
1993 Subaru Legacy Sedan 5 Speed FWD Green (EG33 swap in progress)
1984 Subaru BRAT Tan
droveinmylane
It happens no matter what i could run it all day and it still does it.
How long has it been doing this? Is there any maintenance or anything that may have been done just before this occurred?
BSOD2600
Post by BSOD2600 »
When this was happening to me, I needed to re-adjust the TPS per the FSM.
'11 WRX Limited
'94 TW | R.I.P.
droveinmylane
I haven't done anything to it nothing to the motor at least. Kinda where I headed but I haven't done anything.
Sorry I am noob to this computor controlled what not. What does that mean adjust what where? Lol :wink:
BSOD2600
Post by BSOD2600 »
TPS = Throttle Position Sensor
FSM = Field Service Manual. This is posted in the stuff you need to know forum.
Basically my TPS was starting to fail and it needed to be readjusted to compensate for it going outside of the expected voltage ranges.
'11 WRX Limited
'94 TW | R.I.P.
When did the engine start having the high idle? Or has it always had a high idle since you owned it?
droveinmylane
Just recently it started. like maybe a week. It seems to only do it if I get on it and drive it like that. But once I drive it calmly and be nice it will idle like normal I don't really know if all this makes sense.
subasteve92
Post by subasteve92 »
my 92 legacy used to do the same thing
all i did was just turn the screw by the throttle body to the left 180 degrees
never had a problem since.
______________________________
1992 subaru legacy AWD turbo ej22
___________________________________________
1992 Subaru Legacy AWD turbo
I'd suggest starting by checking to see if any codes are stored in the ECU. instructions are on my site
www.surrealmirage.com/subaru/engine.html
imtb
Post by imtb »
With the warmer weather mine has done this a few times, not sure why or to fix. I have clean the iacv
Has anyone figure this out?
Sometimes the ECU just needs to relearn things if you have ambient changes. You could try resetting the ECU and see if that changes anything.
