WRX Momo wheel
WRX Momo wheel
Is the WRX momo wheel a bolt on affair for the first gen legacy? I have a friend who plans on buying a first gen and is looking at parts.
I know WRX front and rear seats fit.
1996 Subaru Legacy L
1993 Subaru Legacy SS
1992 Subaru Legacy L
1990 Subaru Legacy L
Re: WRX Momo wheel
Doesn't seem like its possible without not having an Airbag. Guess this is one of the ONLY non plug and play things.
Re: WRX Momo wheel
The wheel fits on the splines on the legacy, but yeah, the airbag is several generations of technology newer than what came in the 1st gens so I think getting that to work would be about impossible.
Re: WRX Momo wheel
So it would be possible just to remove the air bag light and never plug the charge in. But that wouldn't be very safe.
Re: WRX Momo wheel
That's what I would do. I'm not sure exactly when airbags were improved, but the early ones were sometimes more dangerous than no airbag...Baddog wrote:So it would be possible just to remove the air bag light and never plug the charge in. But that wouldn't be very safe.
I have an STi wheel in mine, but I never had an airbag so it was a non issue. I should also note cruise control is not plug n play either, not sure if it works or not, but there's definitely rewiring if it does.
Mattheww044
Re: WRX Momo wheel
I have an 05? LGT Wheel in mine. My car didnt come with an airbag, so I dont have to worry about that. I had to re-wire the CC wires, but the horn and CC work so ya...
Re: WRX Momo wheel
Any diagrams or where you guys can point me for the CC and horn wiring?
Re: WRX Momo wheel
Ill tell you what I liked having my airbag.Apex3 wrote:That's what I would do. I'm not sure exactly when airbags were improved, but the early ones were sometimes more dangerous than no airbag...Baddog wrote:So it would be possible just to remove the air bag light and never plug the charge in. But that wouldn't be very safe.
Re: WRX Momo wheel
HOLY cow! Thats intense!!!
Re: WRX Momo wheel
Looks like they have a slightly newer airbag.
My e30 had an airbag, I saw one deployed in a junkyard and it was terrifying
just a big burlap sack basically, thick hard rough material.
Re: WRX Momo wheel
Revisiting this.
Can't I just swap the stalk over to the WRX Momo wheel from my 96 Legacy?
Also about the airbag. Can I just splice on the older style connector and make it work?
oldscoobyturbo
Re: WRX Momo wheel
NO simply rewiring the airbag from a newer model is a bad idea.
Now if you love the look of that steering wheel then remove the airbag.
As for the horn and cruise control they can be rewired or plugs swapped.
Silver 99 Legacy GT Wagon
White 90 BC5 RS Type RA
Re: WRX Momo wheel
Guess I won't be using an airbag then. Sadly it shuts off the passenger airbag.
Sucks they don't make good wheels for the earlier generation.
Horn and CC works now
Re: WRX Momo wheel
There is no passenger airbag in the firstgen Legacy. So no worries for you.
I figure I'm OK with the Momo since earlier cars (91-some 92) didn't have airbags anyway. The car is already designed to help keep you safe in a crash with no airbag. An airbag is a "Supplemental Restraint System" anyway. I'll take my chances without one.
Re: WRX Momo wheel
I have a 96. Has passenger airbag
subaru_styles
Re: WRX Momo wheel
i wonder if the stock airbag unit will fit inside the wrx wheel?
i 've seen them changed out when swapping different (stock) steering wheels on the GD chassis cars
1994 SS "JDM-OEM"
1994 gt wagon, next build
1994 turbo wagon
1994 turbo wagon
Re: WRX Momo wheel
Wish it did but it doesn't you can tell they are different sizes
Re: WRX Momo wheel
I have an 02 WRX Momo wheel in my 96 Outback. If I put the WRX clock spring in I "could" have cruise, but my cruise didn't work when I bought it so I haven't cared. After working at a body shop for many years I don't trust air bag systems, especially not early 90's ones. They are great when they deploy correctly, but the failure rate is really high.
2002 Impreza 2.0RS 6MT
1992 Jeep Cherokee
1994 SS 5MT RIP
1991 SS 5MT *SOLD*
1992 Jeep Cherokee
1994 SS 5MT RIP
1991 SS 5MT *SOLD*
Re: WRX Momo wheel
My cruise and horn both work with my 96 clock spring.
Re: WRX Momo wheel
How much could you get a momo wrx wheel for????? Anybody know what they commonly go for?
BoostedSubie
Re: WRX Momo wheel
I have the wrx momo wheel in 3 of my cars and in one of them, the airbag is hooked up. I work at a salvage yard and blow airbags everyday, crazy how violent they explode. I just changed over the connectors on the airbag, although I'm not sure if it would actually work in a wreck. I used a gen 2 Legacy clock spring as there are two plastic pins that protrude from the clock spring that line up with two holes on the steering wheel that allow the clock spring to turn with the steering wheel but on the gen 1 Legacys, those two plastic pins are on a horizontal plane when the clock spring is in its center position and on the newer 95+ Subarus, those two pins are on a diagonal plane when the clock spring is in its center position. So, if you were to use the gen 1 Legacy clock spring with the WRX momo wheel, those pins won't line up correctly. On my other cars with the momo wheel, I just removed the airbag charge which is held in by 4 8mm bolts.
93 Black Legacy SS
93 Legacy
97 Outback- EJ25D/22e frankenmotor
97 Green Outback
97 Red Legacy GT
98 Silver Legacy GT- Pikes Peak build, built EJ22t/205, GT3076r
99 Black Legacy GT wagon
93 Legacy
97 Green Outback
97 Red Legacy GT
Re: WRX Momo wheel
I don't have an airbag so it doesn't matter. But finding the wheel is a pain in the ass because everyone thinks it is worth $400
