SOLD: Transmission: 5MT - TY752VACCA (I believe) out of a 1997 outback. This is the trans with the low 5th gear (0.871) that is apparently great for rally. I wouldn’t know, I found the low 5th gear a little annoying on the highway, but tolerable. 4.111 final drive. Trans is in great condition – starting to make some noise on deceleration so it probably needs a lash adjustment. 3rd gear is a little crunchy if you’re feeling frisky. Has 110k on it, came out of a wreck. $200 I'll post a pic tomorrow.
Apexi auto turbo timer, Brand New. Don’t know much about this but they are $100 new. Make offer.
SOLD: 2x 5 MT pinion shafts with gears. One has a bad bearing on 1st gear, but the synchros and gear teeth are in great shape. The other came out of a working donor transmission, but the condensation got to outside of it a bit. $15 each.
SOLD: 5MT viscous coupling/center diff, phase 1. Came out of a working trans, unknown condition. I havn’t had this one apart, sounds OK when spun though. $20
SOLD: Misc. 5MT trans tail piece shafts and bearings – all good working condition. $15
1991 SS Auto steering column. Key is in the ignition, comes with cover for wheel (not in pic) - $20
SOLD: 1989-1994 NA Header and Catalytic converter - Brand New Stainless steel! These are about $300, certainly somone must need it... $200 obo.
Auto NA ECU, works fine. $15
5MT ECU – someone wrote “EJ22T” on the side, but I don’t know if it’s actually for the turbo or not. – caveat emptor, $15
1991 EJ22 fuel rails w/ stock injectors. These worked fine. $10
Water pump – no idea about this but the shaft spins and sounds good. $5
SOLD: Brand new rear main seal. $15
Lots more to come! Make offers, take this crap!
