WTB EJ22T complete wiring harness and ECU
ghia nut
Post by ghia nut »
I need on for my ej22t, dont know what year it is but I need the harness and ecu to make it work.
Im in savannah GA if that helps, please let me know
thanks
ghia nut
Re: WTB EJ22T complete wiring harness and ECU
Post by ghia nut »
Bump, pm me what you want so we can make a deal...
ghia nut
Post by ghia nut »
Still need a harness under the intake'manifold, the front main harness for the engine, ej22t ecu, and a MAF
Shoot me a price via pm
ghia nut
Post by ghia nut »
bump, 200?
scoobylover57
Post by scoobylover57 »
pm'd
-Nick-
91 lsi with ej22t swap. work in progress. Sold.
92 SS 5spd. stock. Sold.
94 TW. 6 spd. V2 sti ra ej20g. 550's. rob tune.
94 SS 5spd. stock
bepa
Post by bepa »
good morning, sorry for delay. I have a complete harness. not sure about the ecu. believe I still have it. am in new york and can send it out quickly.
I paid $150 for it. then fixed the problem in the harness in my SS.
let me know if you still need it.
91 SS/ 01 MB ML 55
Bronx, NY.
bepa
Post by bepa »
year is important for this. 90-91 has round connectors and 92-94 has the square ones. these are the connectors for the engine harness. they are on the drive's side next to the battery.between battery and the fuse box.
be well and good hunting. Bepa
91 SS/ 01 MB ML 55
Bronx, NY.
wtdash
Post by wtdash »
Old post....hopefully they've got one by now.
bepa wrote:year is important for this. 90-91 has round connectors and 92-94 has the square ones. these are the connectors for the engine harness. they are on the drive's side next to the battery.between battery and the fuse box.
Hi,
You've got 'em switched...the '90-'91 are square...just finishing the install in my EJ22T w/DOHC heads.
What year is the car??? That's what matters for the harness.
You CAN USE your non-turbo harness, if you still have it...just extend/rewire the coolant temp/gauge sensors.
I may have one, too.
GL
TD
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
bepa
Post by bepa »
thanks for the correct info. but the point was I have one. I also have a 91 SS auto, waiting for replacement trany.
on my 92 SS stick I had an electrical problem. got a complete wiring harness and then found the problem in my harness. now I have a complete wiring harness and would like to offer up herre for someone who can use it more then me.
if you are local and can pick it up I can work with you on the price. to ship it will be a little extra. should be able to go in a flat rate box. usually cheaper and still quick.
again thanks for reading this and safe quick driving. schools are close; watch for kids at play.
be well, Bepa
91 SS/ 01 MB ML 55
Bronx, NY.
