1993 Legacy Wagon.
The driver's window works and none of the others work at the drivers door or at their own switch. I could not find a fuse under the dash or hood that said anything about windows. Did I miss what the fuse is that I should be looking for? Is there another location for the window fuse? Why does the driver window sitll work? Thanks in advance.
3 of 4 windows do not work
Re: 3 of 4 windows do not work
I kind of have the opposite problem. There's no power to the door behind the driver's door. No locks and no window function. Haven't tried figuring out why yet because nobody ever rides back there lol.
ROFL
um FXDWG.....try....oh I don't know.....the lock out switch
94 tleggy wagon, 22t with 2.5 dohc heads, pp6, tdo4, fmic, 3inch catless bpm turbo back, wrx brakes, MANY interior mods to list
Haha, that was my first thought, too.__TT__ wrote:ROFL
I'm glad you don't know my real name or where I live. I had never looked that close at that button to see what it does. I will go hit myself repeatedly with the "duh" stick.
Happens to the best of us, sometimes. Have you figured out the button on the top of steering column does yet?
I had this happen to me ,I took the pass. door card off and fogot to pulg back in power to the window switch,so i would pull off your passenger door and see if your connectors are un pluged...good luck
Let the Haters Hate.
Parking lights AKA corner lights. Turns them on when the headlights are off. There's been a couple reasons I couldn't figure out why they were still on after shutting the car off and walking away.mike-tracy wrote:Happens to the best of us, sometimes. Have you figured out the button on the top of steering column does yet?
