Stock legacy top hats on the '05 WRX spring
1evlwrx
Post by 1evlwrx »
can you run the stock legacy top hats on the '05 WRX spring? or is it necessary to slot the body?
wtdash
Re: Stock legacy top hats on the '05 WRX spring
Post by wtdash »
Welcome to the BBS.
This is likely covered in the Sticky @ the top of this Thread.
Td
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
Yes, you can. But the '05 springs are tapered, i believe, making the use of pre-facelift ('89-'91) tophats necessary. Using those, you wouldn't need to slot the body.
The suspension compendium thread covers all of this, but it can be a bit daunting to read through.
