i been thinking about swaping my motor 5mt in my na thats an automatic i was just woundering how long does this take i know a couple people have done this can it be done in 2week are less working on it every day
and i seen a parts list but ima just put the parts i think i need ej22t 5mt clutch pedal asembly clutch mastercylinder driveshaft rear diff ecu and harness and i need the crossmember for both engine and tranny
is theres any thing else i need and what should i buy new clutch timeing belt water pump and engine tranny mounts idk ALSO if i bought another ss that auto would it be any less work like electrical wise THANKS
time frame
Falken-18c
Re: time frame
So just to clarify, You currently have a non-turbo automatic AWD that you want to swap in a turbo motor and 5mt AWD transmission?
What year is the non-turbo automatic? Depending on the year you may not need to swap the rear diff.
Yes, if you bought a SS that had an automatic transmission, it would be much less work from an electrical point of view to just swap in a 5mt transmission.
Falken-18c
Re: time frame
its an 92 awd na THANKS
Re: time frame
The 92-94 non-turbo auto's came with a 3.90 final drive ratio, so you shouldn't have to swap the rear diff if you swap in a turbo MT.
Falken-18c
Re: time frame
cool thats awsome thanks for the info
