1993 Legacy ss 5mt
The car runs very good.
It has very clean interior and some body damage.The car has around 176 ***
pics at http://s1226.photobucket.com/albums/ee413/vicino1/
Platform:
· 1993 Subaru Legacy Sport Sedan 5-speed
· Winestone Mica-Metallic
· Rare Black Interior
· Fully loaded – Power Moon Roof, ABS, Factory CD Player
Modifications – Engine/Drivetrain:
· Joe-P MBC set to Approximately 12psi (~$50)
· Magnecore Competition Spark Plug Wires (~$90)
· D.E.I. Thermowrapped Turbo and Downpipe (~$55)
· WRX Top Mount Intercooler (~$100)
· HKS Super Sequential Blow-Off Valve (~$200)
· VRG3 Fuel Cut Defender Wired into ECU so car can run unlimited boost (~$50)
· Full Stainless Steel 3" Turbo-Back WRX Exhaust, Custom Modified for the Legacy (~$650)
· Factory Down-Pipe port-matched to turbo
· Shifter linkage bushings
· Brand new Front Driver-Side Balljoint
· Subaru Turbo Exedy Clutch Set (~$176)
· WRX Shifter Linkage with Chopped Shifter (~$100)
Modifications – Suspension/Handling:
· 22mm Whiteline Front Sway Bar (~$150)
· Whiteline HD Endlinks for Front Sway Bar (~$150)
· KYB AGX Adjustable Struts (~$600)
· 18" Kazera Rims with Goodyear KDW Tires (~$800)
Modifications – Brakes:
· Front Autozone Rotors with Lifetime Warranty (~$100)
· Rear Brembo Rotors (~$100)
· Fedrodo DS2500 Pads Front and Rear (~$230)
· Calipers Custom Painted Black (~$20)
· Speed Bleeders Installed at All Four Corners(~$20)
· Synthetic Brake Fluid Installed ($20)
Modifications – Exterior:
· Sylvania Xtra Bright Bulbs (~$40)
· Catz XSL Amber Fogs Custom Mounted in Factory JDM Location (~$100)
· Custom Australian Domestic Market RS-Turbo Decals in Black and Gold (~$25)
· Car Tinted to Legal Limit - 42% Sides, 20% Rear (~$190)
· Brand new front winshield
Modifications – I.C.E. and Misc. Interior:
· Kenwood Stereo with MP3 Capability (~$150)
· Alpine Type-R Speakers (~$200)
· HKS Tyoe-1 Turbo Timer (~$100
· Autometer Carbon Fiber Boost Gauge (~$50)
· Autometer Carbon Fiber EGT Gauge (EGT not hooked up) (~$100)
· Gauges and Turbo Time Installed in Custom Panel featuring OEM 1993 Turbo Seat Fabric
· WRX Shift Knob (~$50)
· Interior Always Protected with Aerospace 303
Included Parts (not currently installed):
· Silencer Tip for WRX Exhaust (~$50) not installed
· WRX Muffler Repainted with Aerospace 303 High Temp Anti-Rust Paint (~$100) not installed
· Full Set of Factory OEM Manuals (~$200)
· Alot more parts that im forgetting!
New Factory Parts/Restoration:
· New Front Passengerside Axle (Constant Velocity.com) (~$67)
· Undercarriage, Rockers, Behind Fenders, Rear Passenger Side Door Coated with POR-15 Anti-Rust Paint (~$150)
· New Turbo-Hood, Turbo-Front Fenders, Turbo-Front Doors, Front and RearTurbo-Bumpers, Turbo-Grille - all Por 15'd (~$550)
· New Timing Belt and Idler Pulley #2 (~$85)
· New Alternator (~$100)
· New Knock Sensor (~$40)
· New Radiator (~$110)
New cam sensor ($240)
Known Issues:
· Power Antenna Gears are Stripped (Common problem with cars with power antennas driven in sub-freezing weather – they ice over when retracted over night, and once the car is started in the morning the antenna cannot extend, causing the gears to strip. Same thing happened on the Lexus…) Antenna has been disconnected – can be replaced easily for approximately $20 if you want.
· AC Compressor Doesn't Work (Common Problem with these cars). Replacement A.C. Compressor can be bought for ~$50 used. A.C. Compressor and components have been removed
Kelley Blue Book Value of Factory 1993 Subaru Sport Sedan:~$2,000
Note: KBB does not take into account the true "Market Value" of this car due to its rarity
asking 3500obo 203 305-6962 thanks nick.
email nicv217@aol.com
1993 legacy ss 5mt milford ct 3500obo
