Cocktail mix foamy?
lucas
Cocktail mix foamy?
Post by lucas »
just did the cocktail mix drove around checked fluid. Pretty foamy. Added both hypoy C and shockproof topped off with sycromesh
1993 legacy ss "Shela"
Deride
Re: Cocktail mix foamy?
Post by Deride »
I didn't like the mix one bit. My front diff whined quite loudly with the cocktail mix in it while ice racing. I only run plain old 75w90 or subaru extra S in my gearboxes now.
2002 Impreza 2.0RS 6MT
1992 Jeep Cherokee
1994 SS 5MT RIP
1991 SS 5MT *SOLD*
I would stay away from the cocktail. Subaru Extra S is the proper oil for these finicky transmissions.
Grayguy
Cocktail mix foamy?
Post by Grayguy »
If I had a 6mt, I'd run the extra S, everything else gets 80w90, of the dead dinosaur variety, usually pennzoil or valveline.
92' SS: SOLD
n2x4
Post by n2x4 »
I'd also avoid the cocktail. Reports have surfaced about damage this mix does to Subaru transmissions.
SUBARUEHS Racing
lucas
Post by lucas »
hmm will pick up some extra S. waste of 30 bucks
Mattheww044
Post by Mattheww044 »
not to steal the post, but does the Subaru Extra-S Work for our tranny and rear diff?
How much will I need total? (for both if applicable)
Do you guys recommend any additives, or just the Extra-S?
Ya that cocktail mix is crap I ran the same in my car and it was whiny as well!! I assumed it was prob just the transmission bearings, but probably would have been much quieter if I tried just straight gear oil.
Deride
Post by Deride »
Just extra S and like 4.2qts for the tranny I think. I wouldn't use it in the rear diff.
1992 Jeep Cherokee
1994 SS 5MT RIP
1991 SS 5MT *SOLD*
Mattheww044
what would u recommend for the rear diff?
Deride
Post by Deride »
75w90 or 80w90, no additives unless you have an old clutch type LSD then I'd go redline 75w90 NS. R160 rear diff takes a quart.
1992 Jeep Cherokee
1994 SS 5MT RIP
1991 SS 5MT *SOLD*
Mattheww044
Hmmm... Ill probably just get whatever subaru makes if they make anything for the LSD Rear Diffs
Deride
Post by Deride »
If it is a viscous LSD unit just use 75w90.
1992 Jeep Cherokee
1994 SS 5MT RIP
1991 SS 5MT *SOLD*
Mattheww044
What brand do you recommend? Mobil?
The extra-s is fine for the rear diff. It is much less finicky than the transmission, so any GL5 rated gear oil should be fine.
Mattheww044
sounds good, I'll get some ordered ASAP. Anyone know the fluid capacities off the top of their head for the 5MT tranny and 3.9 VLSD diff?
You'll need 5 qts. The trans takes just under 4 qts, and the rear diff takes just under 1 qt.
