Ej22T MAF
ghia nut
Ej22T MAF
Post by ghia nut »
Can a MAF from an ej22 be use on an ej22t?
can other mafs be used other than the ej22?
BSOD2600
Re: Ej22T MAF
Post by BSOD2600 »
EJ22 MAF aka 'JECS' or AUTECS can only be used in the EJ22T if you have engine management to compensate for the different airflow rates. There is also a wire mod needed for this swap, unless the engine management compensates for it (like Revtronix).
There is a range of MAFs which work in the EJ22 from other subarus.
'11 WRX Limited
'94 TW | R.I.P.
Re: Ej22T MAF
The silver Hitachi MAF's found on the 90-91 MT non-turbo EJ22's will work with the EJ22t's
