Engine Swap for the daily...
forcefed44
Post by forcefed44 »
Subject: 92 Legacy NA Autobox wagon..
I am contemplating getting fresh heads, and small power adders for the Autobox 2.2 but I wanted to know if there were any other engines that might be a greater gain that will not have to need a major harness swap.. With over 230K on the factory engine.. I want to see if there is anything out there...
Chris M.
92' Legacy L Wagon.. Lifted, KYB's and Borbets....
Re: Engine Swap for the daily...
Not really....you'd need to do harness swap and other work to use other engines.
