93 Loyale Transmission question.
Will it work with my 97 LSi? If so, any idea on what it would take to make it work? I found one for $150, with axels, and a clutch. The seller also says it has push-button 4 wheel drive.
Jesse James
Nintendo Technical Support Representative
Link To Nintendo Technical Support Thread
1994 Impreza Wagon 5M/T
1997 Legacy LSi A/TRamsey Clark wrote:Who will protect the public when the police violate the law?
- quasi-mod-o
Re: 93 Loyale Transmission question.
There are adapters to bolt the transmission up to your engine (search 'EA-EJ adapter' on the USMB), but you'll have issues matching up final-drive ratios and CV axles though.
I think it would be more trouble than it's worth... plus, if you want to research overseas, some Legacies came with dual-range transmissions.
Sent from my HTC Droid Incredible using Tapatalk
Dual Range Transmission? Thanks for the info btw.
Jesse James
The dual range is basicly a hi/lo 4wd transmission, I think the mid to late 80s gl wagons got them. I do know they came before the push buttom 4wd. The best way to explain them is think of the transfer case of a truck, thats basicly the dual range transmission.
Danny
