Dual Range Transmission
TBFK
Post by TBFK »
Can anyone help me locate a Dual Range Automatic Transmission for my 97 LSi?? I've been searching for days, and I know that those transmissions don't come stock with the US Subaru Models. But I still can't find any. Thanks for any help in advance!
Jesse James
Nintendo Technical Support Representative
Link To Nintendo Technical Support Thread
Ramsey Clark wrote:Who will protect the public when the police violate the law?
1997 Legacy LSi A/T
1994 Impreza Wagon 5M/T
Re: Dual Range Transmission
You would have to find one from an older 80's Subaru and then use the adapter plate.
You could maybe find one overseas, but shipping would probably make that not as attractive.
I don't know how well that would hold up to the greater power and weight of the 97 LSI.
Agreed....I probably wouldn't put an EA series trans in an EJ....but it is an option.
I'd try an importer. Foresters and maybe Legacys came with dual range in Australia, possibly other markets.
TBFK
Post by TBFK »
I have been trying to figure out how to buy stuff from out of state, but i'm coming up dry... Does anyone have any tips or how to's on shopping out of country?
Jesse James
1997 Legacy LSi A/T
wtdash
Post by wtdash »
Hi,
Please post a link to where you found an Auto Dual Range reference. I've only read about the Manuals having that option.
Here's a Link w/some useful info...again, only Manual dual-range listed...although the newer CVTs may have it down-under.
Also, found this in an Aussie Subaru AWD document HERE:
Dual Range Shifting - Shifting All-Wheel Drive
Some Subaru manual models come with a dual range function. This allows switching to a
lower gear range that provides more engine torque multiplication. This is useful when
climbing steep slopes, or negotiating difficult terrain, as it provides both additional pulling
power and engine braking. Automatic models do not require the dual range function
because they have a torque converter that automatically increases available torque for
negotiating tough terrain.
Edit. Also, you're FD ratio may require a different rear differential. I 'think' the LSi, which has the EJ25
is the same as the Outback (and GT?) which is 4.44...but haven't confirmed that yet. Otherwise it's 4.11 like the other Legacys. According opposedforces.com yours IS the 4.44 - LINK.
TD
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
TBFK
Post by TBFK »
I haven't found any information on a Auto Dual Range Transmission for the EJ Series, but I do know that one of the EA Series from the 80's had an A/T that had the Dual Range option.
I'll continue my research and post anything I find.
Jesse James
1997 Legacy LSi A/T
TBFK
Post by TBFK »
wtdash wrote:Edit. Also, you're FD ratio may require a different rear differential. I 'think' the LSi, which has the EJ25 is the same as the Outback (and GT?) which is 4.44...but haven't confirmed that yet. Otherwise it's 4.11 like the other Legacys.
TD
I'll check my rear diff gear ratio as soon as i'm off work, and i'll let you know. But as far as I know, they are the same.
Jesse James
1997 Legacy LSi A/T
wtdash
Post by wtdash »
Your LSi should be the 4.44...see my edit above.
Turbo Subies:
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
TBFK
Post by TBFK »
I do see that. I'll double check it anyways when I change the fluid. I haven't changed it since I got the car, and I don't know how long its been since the fluids been changed.
Jesse James
1997 Legacy LSi A/T
mcbrat
Post by mcbrat »
TBFK wrote:I haven't found any information on a Auto Dual Range Transmission for the EJ Series, but I do know that one of the EA Series from the 80's had an A/T that had the Dual Range option.
No.
03 Baja Sport
09 Forester XT Ltd.
82 Brat - Toyota Solid Axles and 36's
martimus919
Post by martimus919 »
The trans will hold up as long as you don't abuse it. I have a AWD D/R from a RX in my Brat with a EJ22 swap, and my buddy put a 5spd D/R from a loyale into his 99 Outback sport. He abuses his car cause he offroads in it alot since he lifted and put that trans in and it's been holding up great for him.
07 Outback XT VF52
94 Legacy Sport, VF23, 550 RobTune, various other things
93 Legacy Touring Wagon EJ205 management and dash swap (in progress)
90 Loyale Turbo, EJ Turbo Swap, 2" lift
82 Brat, EJ22 swap, RX AWD trans w/ LSD rear, 5 lug 4 wheel disc.
SUBYLUV871
Post by SUBYLUV871 »
the old rx has dual. i had one it was an 87.
1998 legacy l wagon
1988 ford ranger prerunner (my baby
martimus919
D/R, AWD, rear LSD, and Center Locking Diff!!
07 Outback XT VF52
