Sabin's 94 TW
Posted: Thu May 26, 2011 7:34 pm
i picked up my 1994 touring wagon from a member here to replace my outback
it is Aegean blue and has 79k original miles
this car sat parked under a tree for at least the last 7 years. the hood and roof have paint damage from the sap.
the sunroof leaked so the interior smelled. it also at some point had mice living in it, i have found and removed at least 3 nests.
it came with wrx wheels.
so far i have done
clean, clean, and more cleaning
3" catless down pipe
apexi intake
20mm front wrx sway bar
replace power antenna
valve cover gaskets
removed pinstripe
new kyb struts with sti springs and all new hardware
2002 wrx front seats
snorkus delete
gc8 spt red steel strut bar
alpine deck
infinity speakers all around, kappas in the front and reference in the back
4th gen legacy all weather floor mats
replaced the stupid ricer blue headlight bulbs
tap the cross threaded seat bolt
replace the vacuum canister solenoid
general tune up stuff, new filters and fluids
when i got it
yummy rust
bad shot at night with sti front springs and stock rear springs
to do/ parts i have
wrx top mount ic
turbo xs mbc
hks ssqv 3
timing belt
convert to manual front seat belts
sand and polish the headlights
to do/ parts i need to buy
fix a/c
new tie rod ends
new front A arms
boost gauge and wide band
rear sway bar
get a cf sunroof panel
get hardware to make sunroof manual open and close
so far i have done
apexi intake
valve cover gaskets
removed pinstripe
snorkus delete
alpine deck
when i got it
yummy rust
to do/ parts i have
wrx top mount ic
turbo xs mbc
hks ssqv 3
timing belt
fix a/c
new tie rod ends
new front A arms
rear sway bar
