91 Legacy top hat upgrade and fitment
njdriver04
Post by njdriver04 »
Swapping in 05 sti struts and sti pinks into my 94, need to source some 91 tops hats, are there other late model subarus that have the same design and fitment as the 91 top hats, looking for pillowball mounts that might work, would the whiteline 'com' c work?
- can i use the perch from the 05 sti tophats? from what I have read no.
thanks
'04 forester XT
Scoob Alumni
'94 TW, '96 L, '00 GT
Re: 91 Legacy top hat upgrade and fitment
I am unaware of any other Subaru that has similar rear top hats as the the 90-91 Legacy.
As you've found, any of the newer ones may be close, but require some modification to get them to fit.
njdriver04
what about the front? if i use shocks and struts from a 96 legacy with sti pinks and the sti tophats would this fit?
'04 forester XT
Scoob Alumni
The front top hats and mounts should work fine.
njdriver04
yeah, i had 05 sti struts not 04, thats where my issue was
'04 forester XT
Scoob Alumni
Baddog
Post by Baddog »
I was going to say the 05 STI strut wont work, the rears will but not the fronts.
1996 Subaru Legacy L
1993 Subaru Legacy SS
1992 Subaru Legacy L
1990 Subaru Legacy L
njdriver04
yea just going to modify the 05 strut (weld/drill)
'04 forester XT
Scoob Alumni
njdriver04
took a trip to the u pull it, decided i am just going to buy new 90-91 top hats from the dealer, instead of a junkyard jem
'04 forester XT
Scoob Alumni
