Wire Broke Off Of Connector
Jessekrs123
Post by Jessekrs123 »
Tooling around the other day with my car to get it started (unplug coolant temp sensor, put in resistor) one of the wires that go into the plug snapped. :x
It broke off pretty close to the connector, and I managed to successfully solder it back into place for now, but it is certainly not a strong fix.
I was wondering, should I get a whole new connector + lengths of wire to splice into the harness wires, or should I just get a new pin for the broken one?
And I just realized that I should have posted this in the electrical section, sorry.
2015 Subaru BRZ
1993 Subaru Legacy Sedan 5 Speed FWD Green (EG33 swap in progress)
1984 Subaru BRAT Tan
Re: Wire Broke Off Of Connector
If you're doing the resistor thing on a regular basis, I would wire in a relay switch of some sorts that you can enable/disable from the cabin with a toggle switch. That will keep you from connecting/disconnecting old brittle wiring/connectors.
It wouldn't hurt to get a new connector with some length of wire to connect things back up.
