is there smaller td04
Falken-18c
Post by Falken-18c »
i have a td04 turbo off of a 02 wrx that came with my car it has no shaft play but the propeller inside seems to be smaller are maybe the same size less its just me i know that one has larger but less blades on the propeller i forget which 1 right now so is the td04 worth puting on if i get the num# off the td04 can any one tell me anything about it
Re: is there smaller td04
Are you asking about comparing the td04 to the vf11?
There are very similar sized turbos. Check out this page, it has some more info on the TD04 near the bottom.
http://www.stealth316.com/2-3s-compflowmaps.htm
The TD04 part of the nomeclature is referencing the size of the turbine side of the turbo. The compressor side is typically what changes and I'm not sure what the specific size the WRX.
Either way, the TD04 is a slight upgrade over the vf11, but you have to rework all the intake piping. So if you're wanting to add an intercooler, the TD04 would be a good route. Otherwise, just stick with the vf11.
Falken-18c
thanks also i have an intercooler that came with the car and thanks to ericem i got 440 injecters also got a wrx coolant tank off him
