Forged Internals
DCM-LEGACY
Forged Internals
Post by DCM-LEGACY »
I'm sure that this question has been all over this form, but im brand new to the EJ22T. I have more experience building the EJ251 and the EJ255.
My question is. Are there any forged internals available for the EJ22T?
PhyrraM
Re: Forged Internals
Post by PhyrraM »
Rods are the same as any other turbo EJ motor.
Wiseco makes an off the shelf piston, others might also. Many go with custom pistons to better match the choice of heads.
Welcome to the BBS.
As PhyrraM mentioned, yes there are forged parts available. Wiseco pistons & Eagle rods seem to be the standard way to go unless you're really mixing and matching heads & block, then you may want custom pistons.
DCM-LEGACY
ok then do you guys suggest just getting a set of EJ205 heads, or EJ257 heads? If i could i would go for EJ207 heads but then again i dont really want to pay that much , i would rather just port and polish EJ205 heads
I'd suggest doing a little more research. The issue you get into when changing heads is that you need to match the intake manifold to the heads, which opens another can of worms with fitment, wiring, sensors, etc.
I'm not sure what you're planning to do with this motor, what car it's going into, what engine management, etc. All those things should be weigh in on your choice. A typical upgrade path for the EJ22t motor that is going back into a first gen Legacy is the EJ20G heads. Here's a link with some more info.
http://bbs.legacycentral.org/viewtopic.php?t=38247
DCM-LEGACY
Legacy777 wrote:I'd suggest doing a little more research. The issue you get into when changing heads is that you need to match the intake manifold to the heads, which opens another can of worms with fitment, wiring, sensors, etc.
Thanks, i was just asking because i currently have a intake manifold from a 06 sti and the heads as well
I think you may run into issues with those heads. I would think the bore of those heads are matched to the 2.5 motor, and may not match up properly on the EJ22t.
DCM-LEGACY
OK thank you , I had them for my EJ251 but never got a chance to actually build it. I love this Forum everyone is so helpful, thanks guys. BTW Anyone know if there is a Difference between the 20G intake manifold and ours?
Florin1
Post by Florin1 »
yes there are multiple differences.
1994 Legacy Sport Sedan.
1991 Legacy Sport Sedan.
DCM-LEGACY
ok well i think ill hold off on going dohc until i can afford the full build lol
Florin1
Post by Florin1 »
You can use your old intake. That will bolt ipod to p1 dohc heads.
DCM-LEGACY
oh really? straight line pattern?
Florin1
Post by Florin1 »
Yup, phase 1 heads/manifold are interchangeable.
DCM-LEGACY
do you know if any after market intake manifolds are phase 1
PhyrraM
Post by PhyrraM »
Just catching up...
If you are asking if the EJ22T intake manifold will bolt to Phase 1 DOHC heads, then the answer is no.
All the phase 1 DOHC heads can swap manifolds between each other, but not between the SOHC versions.
DCM-LEGACY
im mostly just trying to find a intake manifold that is able to allow me to swap in a wrx td04 and run a wrx intake
