Amazed at how clean valvetrain is (pics)
Crashsector
Post by Crashsector »
165,000 miles on stock EJ22. I've only had the car since about 143,000 miles and I had no clue how the first owner took care of it. After doing the head gaskets on what I now realize was a really horribly taken care of Forester, I was expecting a minimal amount of sludge, maybe dark stains on the inside of the valve cover at least. I was shocked when it looked like this:
Needless to say I've worked on engines with half the miles that looked a ton worse than that. After an hour or so of scrubbing with Engine Brite and purple degreaser, the valve cover gaskets were replaced. I went a little overboard cleaning.
This post brought to you by the "my parts didn't show up for my primary project so I dicked around with other little things because I set aside the time anyway" foundation.
--Andy
2005 Impreza 2.5RS. Traded :(
1991 Legacy L w/1994 EJ22T, 16G, WRX 5MT. Sold :(
1993 Legacy L AWD 5MT, 153k miles and many, many more to go.
2008 Legacy 2.5i Limited
Re: Amazed at how clean valvetrain is (pics)
You can never have things too clean :)
ggbox69
Post by ggbox69 »
I experienced the same thing when I did my swap and changed the cover gaskets. The engine had about 136,000 on it and everything looked new, I was amazed. One of my mechanic friends said the previous owner must had been religious about oil changes.
1994 Wagon - Turbo swapped DD
EJ22T, 3'' TBE, Apexi Intake, Spec Clutch, H&R's, Robtune, VF39, 550's, Walbro, V2 STI Top Mount, AEM Wideband
Bheinen74
Post by Bheinen74 »
When i pulled a valve cover to fix a hla on now McBrats 94SS, the inside of the valve cover was shiny still, no sludge, it was clean clean...160k or something like that.
91 Legacy Sport Sedan 4eat
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
