Head gasket replacement parts/tool list.
Rhinoculips
Post by Rhinoculips »
Cant find it in the search....
I have a '91 ej22 engine in my VW van. The head gasket(s) need replacing. Besides the head gaskets do I need anything else to do the job? Bolts? Guess I'm looking for a parts and tools needed list.
I will be replacing one crankshaft gasket. Timing belt has only 20,000 miles on it so I think I will keep that.
H4_Deucer
Re: Head gasket replacement parts/tool list.
Post by H4_Deucer »
2 headgaskets
2 intake manifold gaskets
6 valve cover bolt grommets
2 valve cover gaskets
2 exhaust manifold gaskets
and just for good measure
2 camshaft seals
1 crankshaft seal
1 thermostat with gasket
1 oil filter
some oil
and a gallon of coolant
mrmcq
Post by mrmcq »
I would say a torque wrench with 12 point socket, and a set of metric 6 points. Both Deep and shallow.
A pulley tool or Big Screwdriver/prybar.
A Small allen wrench to pin out the tensioner.
