Stock gearing
Posted: Tue Jul 12, 2011 10:10 pm
by darkcrave
I looked threw about 10 pages but no luck
So
for the 1991 subaru legacy Sport, What are the stock gearing?
Example:
http://www.catherineandken.co.uk/sti/trans.html
Re: Stock gearing
Posted: Tue Jul 12, 2011 11:01 pm
by wtdash
It's in the Owner's Manual, but I found it in the '92 FSM, too - same as '91, I believe:
You don't state which transmission, but the two columns on the right are for the turbo. Look under 'DSPD' for the 5-speed manual; under 'TC' for the 4EAT.
Here's the full page:
Re: Stock gearing
by BSOD2600
Re: Stock gearing
Posted: Tue Jul 12, 2011 11:23 pm
by darkcrave
perfect thank you!!
Last question, does a lower number mean Shorter gears? and a higher number mean taller gears?
Re: Stock gearing
Posted: Fri Jul 15, 2011 6:17 pm
Smaller number means taller gears and faster you'll go. Larger number means more gear (engine speed) reduction and shorter gears.
