Just how long can you drive on a torn CV boot?
Hyena
Post by Hyena »
I'm gonna be taking my Legacy on a pretty long trip here pretty soon, I have no idea how to change the CV boot or axle even myself, so I was wondering if maybe it will be safe? it doesn't "click" or anything when turning or anything like that. Was sort of thinking maybe at least just for the trip putting some axle grease up in there and using a little duct tape or something like that to seal it off? what do you guys think?
Also how long have you gone on the torn CV boot? I've put something like 5,000 miles on mine I think D:
93' Legacy L AWD Wagon- Teal Metallic - Auto
Re: Just how long can you drive on a torn CV boot?
How long is your trip?
I've driven one about 1,000 miles on a joint that was clicking going straight. I smeared grease in there when I got started, which probably helped things.
Liberty10
Post by Liberty10 »
Another duct tape mechanic - I feel at home now :)
I hope you enjoy a trouble-free trip!
'91 Legacy LS Sedan - Misty Dawn Metallic
"There's a crack, a crack, in everything... that's how the light gets in.." ~ Leonard Cohen
07Evolved
Post by 07Evolved »
is it the front or rear cv axle?
Brad
1991 Subaru Legacy L AWD Wagon 5MT (DD)
2000 Outback 5MT (DD)
2005 AW STi
2010 LGT (hers)
1998 Outback (her DD)
Build Thread
Bheinen74
Post by Bheinen74 »
basically, can run it til it runs dry of grease and the ball bearings seize and burn up..........due to heat. it probably will not catch fire.
run it and see. report back.
91 Legacy Sport Sedan 4eat
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
Hyena
Post by Hyena »
Legacy777 wrote:How long is your trip?
ohh yeah not that long. it isn't even clicking yet either. I'm looking at maybe 300 or so miles. I was thinking of smearing grease in there, then duct taping the boot closed where it's ripped haha. not sure how well that will work. Good to know that yours lasted when it was that broken that many miles though, mine doesn't even click with turning yet.
Hyena
Post by Hyena »
Bheinen74 wrote:basically, can run it til it runs dry of grease and the ball bearings seize and burn up..........due to heat. it probably will not catch fire.
Will do! maybe I'll bring a fire extinguisher with me just in case :lol:
Hyena
Post by Hyena »
07Evolved wrote:is it the front or rear cv axle?
front left. From my understanding the fronts go out often because of turning so much or turning the wheel too tight.
CAV3MAN227
Post by CAV3MAN227 »
-I'm about to go on a 1000 mile trip to So. Cal. from Denver and my fronts click a little while turning, and i have a rear inner boot that is ripped. Hope I'll be okay. Well I should cause nothing is different now when i went on my 2000 mile trip to Ft. Hood and back a couple months ago!
-Joe
before i knew anything about cars back in 2004-5 when i had my first legacy, i drove around on a bad axle for well over a year with it clicking...
DevC
Post by DevC »
I ran 6 months on a torn cv, halfway through the winter on the snowiest day after 4 hours of shens and abuse, it failed as I turned into my driveway, drove into the garage with rwd and a slipping center.
93 Turbo Wagon, 5mt swap, vlsd, sti slanty, vf10, alk, subframe lockout, gr2's, sti sways.
96 F-350 CCLB Powerstroke
89 Volvo 244, lsx swap
