What would thing hook up to
slipknot51
Post by slipknot51 »
So i have a question i was just looking over my subaru legacy and i found thing between the runners for the intake and two open ports on the intake ill see if i can upload pictures for you guy other then that i can same the links to the picture.
this im not sure what it was used for
http://i1195.photobucket.com/albums/aa3 ... 24_992.jpg
Here is the open ports im talking about in the intake
http://i1195.photobucket.com/albums/aa3 ... 34_290.jpg
I know that its function must be the same as this one
http://i1195.photobucket.com/albums/aa3 ... 18_331.jpg
this is were its located on the passangers side between the runners
http://i1195.photobucket.com/albums/aa3 ... 20_419.jpg
Thanks for your time People
92 T- leg Tdo4/top mount,3" inch exhaust ,5 speed 2.5 rs trans, sti seats Wrx rear seats kartboy short throw shifter,Kyb gr2 struts
08 Spec b Legacy
Re: What would thing hook up to
It's the canister purge solenoid. You can take some vacuum hose from the auto parts store and connect one end of the metal pipe to the sensor pipe, and then the other end of the sensor pipe to the little pipe on the throttle body.
This is assuming all the stock emissions control piecese are installed, including the charcoal canister. The canister is behind the passenger's headlight.
