1992 Touring Wagon
Josh222
1992 Touring Wagon
Post by Josh222 »
Here is my old beaten up 92 wagon that I have slowly been fixing up on basically no budget. I bought what I thought was a car in great shape that only needed some minor work but it quickly came apparent that the previous owner did spotty work and was a total hack job The joys of owning a car almost as old as I am
So it begins....
Picked up a Invidia Downpipe and a Magnaflow metal highflow cat
Built a jig to hold it and cut it apart to put the cat in and add o2 bungs
Next came brakes
Then I found a melted plug on the heahlight harness while I was replacing the battery
Picked up some Impreza RS seats for a good price to replace my old and torn seats
Came across these for $150 brand new so I couldn't pass them up, H&R legacy springs
Got my wheels powder coated
Replaced the rest of my exhaust with a Blitz Nur Spec system I found on ebay from a jdm twin turbo second gen legacy wagon. Sounds so nice
Now the big work has begun, I was having a problem with loud tapping/banging sounds coming out of the bell housing and the tranny acting funny so Ericem and myself pulled the motor and tranny out.
Here is Ericem happy that the motor is free
Found the cause of all the banging sounds....
Now that the motor is out its time to fix that up and that's as far as I have gotten thus far. Going to replace the timing belt, water pump, spark plugs, wires, cam seals, reseal the oil pump, send the cams off to delta cams for a regrind, replace the valve cover gaskets, new knock sensor, paint the valve covers wrinkle black and the intake wrinkle red, replace the rotted out exhaust manifold and finally install the new tranny
92 Touring Wagon Mica Black(sold)
99 Outback Limited(sold)
05 Outback XT Limited
Josh222
Re: 1992 Touring Wagon
Post by Josh222 »
I started pulling stuff off the motor so that I can clean it as it is really really messy.
3 cans of engine cleaner later and the power washer on it....
Broken flex plate scraped up the back of the block and shaved some metal off, I think I am going to replace that seal.
Looks like the timing belt needed to be replaced anyways....
Got the rest of the motor pulled apart. Nice to see after 18 years it is nice and clean in there
Cut off all the heat shields off my spare exhaust manifold, cut all the mounting tabs off and ground them all down to make it easier to wrap and painted the whole thing. All thats left is to wrap it with some heat wrap
Josh222
Post by Josh222 »
Still doing work to it but it is starting to get there
Old nasty leaky rack
New rack ready to go
Ugly rap job on my exhaust
Painted valve covers
Josh222
Post by Josh222 »
Got my cams back from Delta Cam, got to say they got great customer service every time I called them. Only 1 day turn around time and it only cost me $63.50 per cam
Plenty of hours later and its really coming along
Ericem giving me a hand....
back in there
Picked up some v4 sti suspension this weekend and got that on there with the h&r springs I had. What a HUGE difference, the v4 sti struts are way stiffer and the top mounts were nice and fresh unlike the original ones on the car.
Stock horns didn't work so I picked up some hella horns
Rear trailing and lateral arms off a 93 jdm wrx
the beefier bar mounts off the 04+ impreza
Group A C-Style Endlinks
Whiteline 22mm adjustable swaybar
All new hardware
and
Broken Flex plate
Wrx front brakes with stoptech street pads and super blue racing fluid.. what a huge difference.
Also got some new tires, Yokohama S drives in 225/45/17
My Wagons..
New Vibrant muffler
SiCkSTi04
Post by SiCkSTi04 »
Awesome job on the work you've done so far. Can't wait to see more :)
darkcrave
Post by darkcrave »
Sicccck! lots of nice work! How did those cams open the POS heads up? lol
Tune
TMIC
Fuel
Taillight
Florin1
Post by Florin1 »
Very entertaining read. And thanks for taking all the pictures. Keep it up.
1994 Legacy Sport Sedan.
1991 Legacy Sport Sedan.
Josh222
Post by Josh222 »
darkcrave wrote:Sicccck! lots of nice work! How did those cams open the POS heads up? lol
I raced a friend's 93 turbo sedan also with 4eat, he has a td04 and a top mount on stock boost. I have cams and a turbo back. 1st gear was neck and neck but once we hit second I would pull away.
http://www.youtube.com/watch?v=59NkKaapg3Y
It idles like poo though
darkcrave
Post by darkcrave »
Do Delta have different stages of the cams? they dont sound too bad
Tune
TMIC
Fuel
Taillight
SiCkSTi04
Post by SiCkSTi04 »
darkcrave wrote:Do Delta have different stages of the cams? they dont sound too bad
This.. http://bbs.legacycentral.org/viewtopic.php?f=5&t=42773
darkcrave
Post by darkcrave »
Nice info!
What cams did you get Josh?
Tune
TMIC
Fuel
Taillight
Nice work!
darkcrave wrote:What cams did you get Josh?
I got the 220's. Dan, 93forestpearl had the same grind and he did say there was a little bit of idle lope. I'm probably two weeks or so away in starting up. One thing I can do though is bump the idle a little bit with the stand alone if I don't like the idle.
snailslow
Post by snailslow »
looks good! ive been doing the same with my wagon
93 touring wagon
darkcrave
Post by darkcrave »
Are they basicly drop in cams? nothing else is needed?
Tune
TMIC
Fuel
Taillight
bmxkelowna
Post by bmxkelowna »
you broke two flex plates? very strang, think there might be an other issue causing them to fail?
darkcrave wrote:Are they basicly drop in cams? nothing else is needed?
From what I understand from Delta, yes they are drop in cams.
Josh222
Post by Josh222 »
bmxkelowna wrote:you broke two flex plates? very strang, think there might be an other issue causing them to fail?
One came with the car broken and the second was from a used tranny I put in. I then went and bought a brand new one from the dealer and haven't had any issues since then, almost 10,000 miles ago. There is no play in the crank from a worn thrust bearing or anything like that.
I am running stock tune with them, it starts first revolution of the engine everytime. I get about 17.5mpg average though :(
Headlights polished
Cleaned but still a big rust bucket :D
Timo
Post by Timo »
Cool wagon, with cool mods! 8)
Subaru Legacy Turbo RS
Something needed/wanted from EU, maybe I can help, just pm me!
GTwagon
Post by GTwagon »
very nice wagon.
make's me want to clean up my wagon now after seeing what you have done to yours.
keep up the good work.
oh how was the shift kit after u installed it?
was it worth getting?
Drive it like you Stole it
Josh222
Post by Josh222 »
Danny-G
Post by Danny-G »
Should totally bake the headlights! They go great on black cars.
Danny
Post by SILINC3R »
Really nice setup do you like the invida axle back? Keep up the good work and keep the pictures coming.
Josh222
Post by Josh222 »
The one on the left is a RHD Type RA :D
It has an invidia down pipe with a vibrant muffler. I used to have a Blitz Nur axle back but it was a cop magnet with the 4.5" dia tip.
snailslow
Post by snailslow »
cant wait till i can get mine going!
93 touring wagon
CFK
Post by CFK »
Hey I know it's been awhile since you posted, but I just had a :?:
Do you guys have Emissions testing ? And if so did you pass with those Delta Cams :?:
I got my Engine out and really wanna throw a set of those in, problem being is I already failed emissions without cams lol. Really annoying that you have to pull the heads to Change cams :!:
Nice Wagon, Still Got it :?:
Build Thread : HERE
92 SS 5MT. Project Daily
84 Jetta Coupe. Real Project
99 A4 Avant. Wife's Daily
