does a 1994-2004 n/a impreza pressure plate work on ej22t for the toyota rwd trans. swap.
http://bbs.legacycentral.org/viewtopic. ... n&start=50
it says i need a na pressure plate. does it have to be for a ej22 or can it be ej25? are they the same?
sorry for being confusing
pressure plate
pressure plate
92 turbo legacy: RWD W58 SWAP, td04, 3"tbe, mbc, fmic, wrx brakes/hubs, wrx seats, welded 4.11, fcd, drift steering wheel, Drifting Stickers
Re: pressure plate
I think as long as you match everything, clutch, pressure plate, and flywheel together it should all work.
Re: pressure plate
well to do the supra w58 tranny conversion i have to have a na flywheel, na pressure plate, and supra clutch disc. here is the part in question http://clutchflywheel.com/act/act_compo ... 11-09-1999 and here is the clutch http://www.autopartswarehouse.com/sku/T ... 36207.html
Re: pressure plate
Hmm....well I'm not sure I can help in regards to a Subaru flywheel & pp working with a toyota clutch.
What I'd probably try and do is go to the local autoparts store and see if they have clutch setup for the Subaru and Toyota and ask to see both and try the Subaru pp with the supra clutch. If you have your own flywheel already, bring it in to test everything.
Re: pressure plate
oh good idea ok. will do. thanks
