no power to fuel pump
Posted: Thu Jul 28, 2011 1:14 am
by 91'firebreather
I would like to share some info with you guys.
I own a 91 turbo legacy and I lost all power to my fuel pump. When I replaced the relay
it still didn't work. I was at a loss so on a whim I unbolted the bottom of the back seat
the wires had shorted out and melted the plug together. I cut the plug out and connected
The wires with out the plug and it works.
I posted this to hopefully help others. It is a pain in the A@& to find and replace the relay
Re: no power to fuel pump
Posted: Fri Jul 29, 2011 1:46 am
Welcome to the BBS, and thanks for the information.
Yeah, unfortunately that is a somewhat common problem on these cars, and the easiest fix is to do as you did and just use some separate spade connectors.
Posted: Fri Jul 29, 2011 9:22 pm
by antslegggy
lol, here i was thinkin my car was just a random son of a gun, but low and behold, others have run into this issue. had the exact same thing happen to mine, and did the same thing to fix it.
odd
same year and everything
