I was looking into a bigger fuel pump and injectors for the 91 turbo.
Any suggestions?
more fuel
Re: more fuel
Search... this has been covered many times.
The common upgrade is the walbro 255 pump.
'11 WRX Limited
'94 TW | R.I.P.
Re: more fuel
Thank you I'm new here haven't found anything yet. Still looking
Re: more fuel
You'll need some form of engine management or fuel controller if you change your injectors. I'd suggest checking out this thread.
http://bbs.legacycentral.org/viewtopic.php?f=19&t=43744
Re: more fuel
Thanks for the help.
I have another question that kinda sloped my mind.
Have you heard how the G-Force chip works? if so are you happy with it
Re: more fuel
Hi,
The G-force states it works ".... via 2 wires that plug into the IAT sensor.." .
The Legacy didn't have an IAT 'til....2000? When it went to a MAP-based system vs. the MAF.
The G-force likely tricks the IAT into thinking your car's intake air temp is cooler in order to increase fueling/timing...old 'resistor mod'.
Not sure what it does for the MAF-based Legacy.
Td
Td
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
Re: more fuel
Thanks for the info
