Eg33 supercharged
sleepinsuby
Eg33 supercharged
I have a 92 wagon with a eg33 swap and after many mouths of wiring and the car being on it's second eg33 I feel te need for more. The plan is to use a m90 eaton twin screw sc from a gtp 3.8l v6. I will be completly eliminating the throttle body on the manifold ( from the blown motor ) then some machining and welding to make a water to air intercooler on top of the manifold flowing strait in from the top. Mounting the sc on top of that. Em will mostlikly be mega squirt. Manifold is still in the design process but just wanted your guys .02 on te set up. I'll get some pics up when I get a chance.
•94SS full cage 2.2 hybrid build with 04 2.5i heads,JIC coilovers,jdm 4pots,vlsd,jdm TD05 16g ,top mount IC,950 injectors,running ms3x em
•91ss ej22t 110k,rebuilt heads,new seals,delta220 cams,td04,wrx top mount,wrx flywheel,wrx trans
•92L drift project h6 rwd
Eg33 supercharged
Sounds awesome to me! Is that gonna clear the stock hood?
92' SS: SOLD
sleepinsuby
Re: Eg33 supercharged
hood cutting will be needed but I don't mind some monster motor sticking out haha
I haven't seen him on the board recently, but you may want to pm/email or search for past threads from Douglas Vincent. He was a pioneer when it came to putting Superchargers on these Legacies.
