06 spd into a 93 legacy, linkage questions
Redlined
Post by Redlined »
picked up a 5 speed out of a 06 2.5rs. been browsing the linkage threads and seems like most of the threads are about putting newer shifters into older transmitions. If I got things right in my head I should be able to just use the newer short shift kit, bushings, and linkage, Is this correct?
Also hopping someone can tell me definatively what axle stubs I need.
Deride
Re: 06 spd into a 93 legacy, linkage questions
Post by Deride »
Yep newer linkage from the 06 trans will bolt right up along with any 06ish short shifter etc. Pretty sure you need the same stubs as the 6 speed swap guys use along with the seals. I'm only 98% sure though.
2002 Impreza 2.0RS 6MT
1992 Jeep Cherokee
1994 SS 5MT RIP
1991 SS 5MT *SOLD*
Florin1
Post by Florin1 »
I used my stock front axles. My trans was out of a 04 TS though. 3.9 FD n/a transmission.
1994 Legacy Sport Sedan.
1991 Legacy Sport Sedan.
Redlined
Post by Redlined »
good stuff to hear! Thank you all for the information!
