which one would be best
Front, Top, Air, Water.
Falken-18c
Post by Falken-18c »
which one would be easyest to install
http://s1213.photobucket.com/albums/cc4 ... tercooler/
legacylok
Re: which one would be best
Post by legacylok »
The smaller one will be easier to install because it looks like it has the right y-pipe.
Either way both of those BOV's will probably hit your throttle linkage.
Personally I would take the y-pipe off the small intercooler and but it on the bigger 06 forester one, it should fit with a little work, and is almost identical to my setup.
Kris
92 SS, ej20g, camo wrap, 16g, 06 intercooler,
Robtune, 550s
Falken-18c
kool thanks ill look at it when i get ready to install hopfully soon
SWRT
Post by SWRT »
legacylok wrote:Either way both of those BOV's will probably hit your throttle linkage.
Hopefully it'd hold it wide open so the second you start your car
it'd be nothing but full throttle all the time! HECK YEAH!
Edit: Sorry guys...I get bored at work.
Falken-18c
that would be awsome im down with that jk lmao
Falken-18c
legacylok wrote:The smaller one will be easier to install because it looks like it has the right y-pipe.
so whst do i do so i dont hit the throtle do i need to buy somthing are just raise lower intercooler
Im guessing your only option is to make a custom bpv plate and run the stock legacy bpv like i did.
speedmaxx
Post by speedmaxx »
I ran a stock sti bypass valve and just removed the part that vents it back to the atmosphere, clears the throttle wires good and the car runs fine
93 legacy l
to much to list....
Falken-18c
speedmaxx wrote:I ran a stock sti bypass valve and just removed the part that vents it back to the atmosphere, clears the throttle wires good and the car runs fine
could u send some pics.
I didn't know it vented to atmosphere. I thought all subaru BPVs were just that, recirculating systems.
They should considering all the cars are MAF based.
Mattheww044
Post by Mattheww044 »
The STi is recirc. I think what he is referring to is the elbow that can be taken off of the stock BPV, that is the part that hits the throttle body cables. If you take that off, then it doesn't hit, but its really freakin close. If you do the "crush mod" too the BPV, now BOV, it should help alot with idling and such but it will still run rich between shifts.
SWRT
Post by SWRT »
So it just wouldnt recirculate anymore?
