which one would be best
Posted: Thu Aug 11, 2011 2:07 am
by Falken-18c
Re: which one would be best
Posted: Thu Aug 11, 2011 8:00 am
by legacylok
The smaller one will be easier to install because it looks like it has the right y-pipe.
Either way both of those BOV's will probably hit your throttle linkage.
Personally I would take the y-pipe off the small intercooler and but it on the bigger 06 forester one, it should fit with a little work, and is almost identical to my setup.
Posted: Thu Aug 11, 2011 12:56 pm
by Falken-18c
kool thanks ill look at it when i get ready to install hopfully soon
Posted: Thu Aug 11, 2011 8:08 pm
by SWRT
legacylok wrote:Either way both of those BOV's will probably hit your throttle linkage.
Hopefully it'd hold it wide open so the second you start your car
it'd be nothing but full throttle all the time! HECK YEAH!
Edit: Sorry guys...I get bored at work.
Posted: Thu Aug 11, 2011 11:50 pm
by Falken-18c
SWRT wrote:legacylok wrote:Either way both of those BOV's will probably hit your throttle linkage.
that would be awsome im down with that jk lmao
Posted: Mon Aug 15, 2011 5:19 am
by Falken-18c
legacylok wrote:The smaller one will be easier to install because it looks like it has the right y-pipe.
so whst do i do so i dont hit the throtle do i need to buy somthing are just raise lower intercooler
Posted: Mon Aug 15, 2011 5:33 am
by kimokalihi
Im guessing your only option is to make a custom bpv plate and run the stock legacy bpv like i did.
Posted: Mon Aug 15, 2011 1:29 pm
by speedmaxx
I ran a stock sti bypass valve and just removed the part that vents it back to the atmosphere, clears the throttle wires good and the car runs fine
Posted: Wed Aug 17, 2011 9:19 am
by Falken-18c
speedmaxx wrote:I ran a stock sti bypass valve and just removed the part that vents it back to the atmosphere, clears the throttle wires good and the car runs fine
could u send some pics.
Posted: Wed Aug 17, 2011 11:58 am
by kimokalihi
I didn't know it vented to atmosphere. I thought all subaru BPVs were just that, recirculating systems.
Posted: Wed Aug 17, 2011 5:21 pm
They should considering all the cars are MAF based.
Posted: Thu Aug 18, 2011 6:05 am
by Mattheww044
The STi is recirc. I think what he is referring to is the elbow that can be taken off of the stock BPV, that is the part that hits the throttle body cables. If you take that off, then it doesn't hit, but its really freakin close. If you do the "crush mod" too the BPV, now BOV, it should help alot with idling and such but it will still run rich between shifts.
Posted: Thu Aug 18, 2011 12:11 pm
by SWRT
So it just wouldnt recirculate anymore?
