Brake Pad Question
trlegacy
Brake Pad Question
Post by trlegacy »
Can i use 96-00 impreza brake pads on my 91' legacy ?
Re: Brake Pad Question
Front or rear, or both? It will depend on the brake/caliper size and year. The brake pad tabs changed slightly with the newer Imprezas.
Your best bet would be to find an online parts place where you can drill down to the brake pad part # for the legacy and then check and see if any of the 96-00 Imprezas have the same part #.
trlegacy
Post by trlegacy »
i need front brake pads.i found imprezas front brake pads.i thought it can be fit.thank you
trlegacy
Post by trlegacy »
i need a brake disc for 1.8 legacy.which subaru model use same brake discs.Can i use BD 2.0 GL brake discs?
What year is your 1.8 Legacy? Since we never got the 1.8 legacy in the states, I'm not sure what is going to fit. I would assume similar base model legacies or imprezas would have the same front brakes.
trlegacy
Post by trlegacy »
1.8 gl legacy,1.6 impreza ,2.0 gl legacy have same brake system.discs are 260 mm but turbo legacy's 276 mm. i changed discs and brake pads yesterday.there is no problem now.thank you.
Good to know.
Thanks!
