WTB: TD04 Coolent lines?
darkcrave
Post by darkcrave »
When i put my TD05 on the coolant line was different then the VF11 does anyone know if its the same?
Tune
TMIC
Fuel
Taillight
Mattheww044
Re: WTB: TD04 Coolent lines?
Post by Mattheww044 »
the vf-11 is the one that is 2 seperate lines, with a little bar connecting them in the middle, so one piece, correct? When I put my TD04 on I ran into the same problem. I cut the center piece out and took them both to the grinder wheel to make them smooth. If I remember right they are spaced differently so I had to do that to make it work.
darkcrave
Post by darkcrave »
Yea they have the metal bar in the middle of the two lines, but the lines on the VF11 are smaller vs the TD05 which are much larger. I tried swapping them they are not even close.
because the TD05 coolant line if facing the front of the car and it should be facing the driver side i believe
Tune
TMIC
Fuel
Taillight
Mattheww044
oh ok, I don't think I had that issue with the TD04 if I remember correctly, so the TD04 and TD05 may be different
wtdash
Post by wtdash »
Hi,
The TD05 requires EITHER new lines (see ebay, nasioc, etc) or drilling/enlarging the holes on the VF11's coolant lines AND you'll need new the special banjo bolts to fit the TD05. If you use TD04/VF11 lines you'll need to cut the metal bar.
Edit: The lines from a VF11/Td04 will work on a VF39 'as is'.
I'd do a search on here as it's been covered - probably by me.
GL,
Td
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
