AFR's
darkcrave
AFR's
Post by darkcrave »
What should our AFRs be
Idel
WOT?
Tune
TMIC
Fuel
Taillight
Re: AFR's
Are you asking what the desired AFR's should be, or what you will probably see?
An ideal setup should have AFR's around 14.7 at idle because the ECU should be in closed loop mode reading and adjusting values from the O2 sensor. There really shouldn't be anything you can do to modify this.
At WOT and into boost, you'd probably want around 11.0. This is assuming you have a good intercooler and your intake temps are not too high.
For what you may see on a stock ECU, at idle, you'll probalby see the 14.7. For WOT, it's going to likely be in the 10 - 10.5 range, or possibly lower.
darkcrave
Re: AFR's
Post by darkcrave »
okay sweet, what would be Lean?
Tune
TMIC
Fuel
Taillight
Re: AFR's
What do you mean "what would be lean?". Anything above 11 in boost is going to be leaner than I'd want to see. I suppose you could maybe go to 11.5, but that'd be pushing it.
darkcrave
Re: AFR's
Post by darkcrave »
Sorry i have no ideas what the numbers mean, at idle its about 15. normal driving about 12-13. WOT 9.-11.
Tune
TMIC
Fuel
Taillight
Florin1
Re: AFR's
Post by Florin1 »
You're good.
1994 Legacy Sport Sedan.
1991 Legacy Sport Sedan.
