top mount y pipe ?'s
Front, Top, Air, Water.
Mt.HOODrat
Post by Mt.HOODrat »
so the general consensus is that the 06-07 tmic fits best, and it is my understanding that a 02-05 y pipe fits best as well? ive looked through a lot of the threads about td04 and tmic installs, but everyone does it different, and its all sort of unclear. is there a thread that shows what everyone agrees is the best tmic solution? i pretty much know that i will have to cut up a spendy silicone y pipe, but i just want the simplest solution possible. thanks in advance
BSOD2600
Re: top mount y pipe ?'s
Post by BSOD2600 »
The sticky in this thread not have enough pics?
'11 WRX Limited
'94 TW | R.I.P.
Mt.HOODrat
it did, and i thank you bsod for that badass write up. thats the method i plan to use know, i just wanted to see if anything else came out of the woodwork, but it seems that your setup is probably the best one.
ravencroft89
Post by ravencroft89 »
hey bsod you think u could post that stickey again im just trying to get a feel about what i need to do to put on my 06 tmic
ravencroft89 wrote:hey bsod you think u could post that stickey again im just trying to get a feel about what i need to do to put on my 06 tmic
It's at the top of the forum.
http://bbs.legacycentral.org/viewtopic.php?f=3&t=38598
