So here goes:
Intake manifold 3 w/ throttle body, 2 w/ harness, 1 w/ IAC sold
Radiator fans (pair), 2 available
N/A heads, 1 pair
Oil pump, stock, 2
Coolant crossover tube, 2 n/a, 1 turbo
IAC, 3 sold
Various cam and crank timing pulleys for EJ22 and EJ25 (even one AVLS cam pulley, don't ask)
Harmonic balancer/crank pulley, 3
Timing tensioners, a few old style, one new style w/ mount bracket
Engine mounts, 1pr. n/a, 1pr. turbo
Various timing covers
Shifter assy., 2 1 sold
Various swaybars, all stock, from stock turbo Leg to WRX, front and rear
Swaybar bushings, a few stockers, 1pr. COBB (new)
Tail lights w/ center section sold, post-facelift
Wagon tail light, right side
Headlight, pre-facelift, right side
Marker/corner light, post-facelift, right side
Sun visors, light grey
Sun visor, light blue, right side
Various center console/radio mount stuff, .5 DIN filler panel sold
ECU, 2 n/a, 1 turbo
V.2 slanty TMIC
Also available but not pictured, BNIB stock replacement, metal end tank, radiator for n/a Legacy. Paid $100 a year ago and didn't end up needing it. Make offer.
Pics enlarged for clarity and prosperity. If you see something you want thats not listed, its available, make an offer.
 You make my spare parts reserve look like nothing!  Extra points for the Summit box (I was born in Summit County, Ohio)!
