wrx clutch in a legacy?
s1d3way
Post by s1d3way »
hello i just picked up a 94 legacy ss. unfortunately it needs a new clutch. it sounds like the wrx clutch will bolt on but i would like someone to confirm this for me. i assume i need a flywheel from a wrx too? and is there a specific year wrx clutch/flywheel i should get? thanks in advance for the help!
Alphius
Re: wrx clutch in a legacy?
Post by Alphius »
I bought an "Exedy KSB-03" for WRX and it works and fits fine on a stock Turbo Legacy flywheel. The diameter difference is like 225mm vs 228 mm or something, so it has no issues with being a little bit larger than stock. :)
Make sure you get your flywheel resurfaced if it is messed up.
Welcome to the BBS.
Yes the WRX clutch & pressure plate will work. I'd suggest just getting a WRX flywheel, especially if the existing flywheel needs to be resurfaced.
You'll need to get a WRX clutch/flywheel setup from these MY's 2002 - 2005. I think in 2006 they went to a push clutch setup, which is different. Hopefully someone can confirm or deny that.
wtdash
Post by wtdash »
^Correct.
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
darkcrave
Post by darkcrave »
Yea i have the Exedy WRX Clutch kit in mine also no problems
Tune
TMIC
Fuel
Taillight
05SRT
Post by 05SRT »
Same for 91s? So i can get a stiffer clutch from 02-05 WRX? Bad ass.
-Lindsay-
2005 SRT-4-Track Slut
1991 Legacy SS-DD/Tinker Toy
darkcrave
Post by darkcrave »
^ Yes sir! Grab a shifter linkage from a WRX while your down there!
Tune
TMIC
Fuel
Taillight
