wrx clutch in a legacy?
Posted: Tue Sep 20, 2011 12:08 am
by s1d3way
hello i just picked up a 94 legacy ss. unfortunately it needs a new clutch. it sounds like the wrx clutch will bolt on but i would like someone to confirm this for me. i assume i need a flywheel from a wrx too? and is there a specific year wrx clutch/flywheel i should get? thanks in advance for the help!
Re: wrx clutch in a legacy?
Posted: Tue Sep 20, 2011 2:29 am
by Alphius
I bought an "Exedy KSB-03" for WRX and it works and fits fine on a stock Turbo Legacy flywheel. The diameter difference is like 225mm vs 228 mm or something, so it has no issues with being a little bit larger than stock. :)
Make sure you get your flywheel resurfaced if it is messed up.
Posted: Tue Sep 20, 2011 5:36 pm
Welcome to the BBS.
Yes the WRX clutch & pressure plate will work. I'd suggest just getting a WRX flywheel, especially if the existing flywheel needs to be resurfaced.
You'll need to get a WRX clutch/flywheel setup from these MY's 2002 - 2005. I think in 2006 they went to a push clutch setup, which is different. Hopefully someone can confirm or deny that.
Posted: Wed Sep 21, 2011 10:14 pm
by wtdash
^Correct.
Posted: Sun Sep 25, 2011 9:57 pm
by darkcrave
Yea i have the Exedy WRX Clutch kit in mine also no problems
Posted: Mon Sep 26, 2011 3:18 am
by 05SRT
Same for 91s? So i can get a stiffer clutch from 02-05 WRX? Bad ass.
Posted: Mon Sep 26, 2011 5:40 am
by darkcrave
^ Yes sir! Grab a shifter linkage from a WRX while your down there!
