One or two more things for the newbie. Make sure any engine or trans you get
is a turbo engine and turbo trans. The US Legacy Turbo 2.2 engine is
different from any other US Subaru engine on the inside where it counts. The
normally aspirated N/A 1.8, 2.2, and 2.5 engines are NOT the same as the
turbo engine. Neither is the Engine Control Unit (ECU) Likewise, the auto
tranny that came with the turbo is NOT the same as the auto tranny on the
normally aspirated engines, nor is the separate Transmission Control Unit
(TCU). HOWEVER, the 2.2 turbo auto trans is similar and may be the same as
the auto trans used on the even more rare SVX 3.3 liter six cylinder Subaru
sports car that pushed about 300 horses, so that might give you a litter
wider search pattern. If given a choice I would say do a rebuild. Dave, as
for pics of my wagon, you don't want them. My wagon is a stone cold stock
dark red car that is indistinguishable from any other 92 Legacy wagon except
for the hood scoop, the practically invisible "TURBO" emblem on the tailgate,
and maybe the factory turbo wheels.
Thanks anyway for the invite. Larry Witherspoon.
Make good on the promise you made at graduation to keep
in touch. Classmates.com has over 14 million registered
high school alumni--chances are you'll find your friends!
http://us.click.yahoo.com/03IJGA/DMUCAA ... /X7OVlB/TM
---------------------------------------------------------------------_->
newbie advice and wagon pics
Good info.
The SVX was only 230hp, however.
Basically everything on the Turbo models was made stronger than the
lower models. Unfortunately the engine is really poorly tuned and
could have made at least 220hp with an intercooler and a bit more
boost.
I aim to correct this oversight!
trans you get
is
counts. The
as the
the auto
on the
Control Unit
same as
cylinder Subaru
litter
Dave, as
cold stock
wagon except
tailgate,
boost.
trans you get
is
counts. The
as the
the auto
on the
Control Unit
same as
cylinder Subaru
litter
Dave, as
cold stock
wagon except
tailgate,
I have an Australian spec Liberty RS Turbo with the EJ20 intercooled turbo (IHI RHB52) which I think makes around 200hp. Does anyone know whether I could put 2.2 Legacy Turbo heads or 2.5 Legacy/Impreza heads on my block? Or would I be better off with 2.0 WRX heads?
Ross
----- Original Message -----
Sent: Saturday, 24 March 2001 6:24 PM
Subject: [BC-BFLegacyWorks] Re: newbie advice and wagon pics
Good info.
boost.
trans you get
is
counts. The
as the
the auto
on the
Control Unit
same as
cylinder Subaru
litter
Dave, as
cold stock
wagon except
tailgate,
<http://rd.yahoo.com/M=170602.1361328.29 ... icated.com> www.debticated.com
<http://us.adserver.yahoo.com/l?M=170602 ... =609441165>
Ross
Good info.
boost.
trans you get
is
counts. The
as the
the auto
on the
Control Unit
same as
cylinder Subaru
litter
Dave, as
cold stock
wagon except
tailgate,
