kyb fitment Q
kyb fitment Q
A local seller is looking has a set of 4 KYB GR2's that will fit 96-99 legacy/outback. Direct fit on our 94 wagon? or still our 92 L sedan? Springs would remain OEM.
Re: kyb fitment Q
The damping rates & perch height may be a little different, but should should physically fit. The perch height difference could alter the height of the car.
Re: kyb fitment Q
okay, thank you. also, are wagon and sedan struts interchangeable? springs? among same generation? 92 sedan, 94 wagon.
Re: kyb fitment Q
Subaru lists different part #'s, but I don't believe most aftermarket companies, like KYB differentiate between wagon & sedan struts.
