wheel/hub question
silver03
wheel/hub question
Post by silver03 »
I bought a set of 14" steelies with near new winterforce on them that came off a dodge stratus. . Bolt pattern is the same, no offset issues. I don't want to have issues due to bore size....but will I? Subie bore is 56.1mm and the stratus is 57.1. Input appreciated. thanks
Re: wheel/hub question
You should be ok. My wheels are lug-centric wheels (like the dodge's) vs. Subaru's hub-centric. I'd suggest just getting the lug nuts centered good and finger tightening all of them before torquing.
